l series clutches
From adelaide
is it possible to get the pressure plate and flywheel if needed from a bigger engine say 260z or 280 and use the clutch disk that suits the splines on my gearbox. Not sure what box it is, it is was from a bluebird that was converted to 5spd from an auto. All behind l20b.
Posted on: 2005/5/31 3:52
Re: l series clutches
From Brisbane, Australia
yes, the 6cyl flywheels will fit the L20B crank (6 bolt), but not the L16/18 cranks (5 bolt). All L series gearbox input shafts are the same spline.
Its probably overkill though - I always ran a Sports 2000 clutch, which bolts straight on the 4cyl flywheels.
Posted on: 2005/5/31 5:57
