Toyota T50 gearbox question
From Sydney Australia
I have recently purchased a toyota (yes I know toymotor) T50 5 speed and there is oil in the bellhousing and it smells like gear oil.... so im guessing that the front main seal is leaking.
Does anyone have any experiance with these boxes or is there anyone that can tell me how to fix this? or maybe Im better of taking it to a gearbox place.
Posted on: 2005/6/8 13:41
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Re: Toyota T50 gearbox question
Did you buy a car with the gearbox in it, or just the gearbox?
If it's just the box, then i assume that you will be using it behind a Datsun engine. [a lot of assuming going on here.]
The Dellow bellhousing incorporates the front part of the box, so you will need to install a new seal anyway. If no Datsun engine, then a pox on your gearbox, but untill it kicks in, see if you can get a Gregories on that car model. It will be a lot cheaper than a tradesman doing it & it shouldn't be a hard job..
Posted on: 2005/6/8 13:49
Love your Datsun.
Treat it well.
Yeah the box has the datto conversion done already I bought it with an A14
That sounds good that I can do it my self cheers dodge.
Anyone know what car that box is out of?
I heard it could be out of a sprinter but im not sure , I will do a search tomorow I need to catch some zzzzzzzzzzzz's now.
Posted on: 2005/6/8 14:25
From T'ville
Ithink they are from a celica with the 2T or 3T engine
Posted on: 2005/6/8 22:18
From Springwood NSW, Formerly Tas.
T50
TAxx series celicas
TExx corollas/T-18
AE86- sprinter
yeah anything with a T or a RWD A engine
K50 5spd
KE70 1982 "xx" corolla sedan top of the range
there were also some other KExx cars with the K50 such as the KE50 2 door hatch/liftback (similar to the t-18 just earlier)
Posted on: 2005/6/9 2:45
1978 120y Coupe.
Cheers fellas.
Talked to a mate who has a sprinter today and he said its an easy job all I have to do now is get the part.
Posted on: 2005/6/9 13:17
From Australia, NSW near Tamworth
count the splines on the output shaft, the stronger t50's had 22 or 23 spline, the weaker ones 20 spline. dellow sells the yoke to fit the 22/23 spline for $100, good luck finding one of these at the wreckers. The t50 bellhousing has a paper gasket between it and the gearbox. If it leaks it has the gear oil smell (sulpur/crappy smell) unlike engine oil. Check this first.
If you are smart you can use a datsun 1200 clutch fork, cut a square hole on drivers side of the box and keep your datsun cable clutch. Mine has been working well for over 12 months and is as light as.
The tailshaft from a mazda 929 wagon is also a close fit, check this out as well.
Posted on: 2005/6/10 13:57
Cheers Ill count the splines tomorow.
The bellhousing is for a cable made like that from dellows. It just uses the original clutch cable.
Posted on: 2005/6/13 13:39
I tripple counted the splines on my gear box and there is 21 splines.
Would all these gearboxes have different seals? or the same?
Posted on: 2005/6/20 15:39
Not too shy to talk
From Brisbane
I can't remember the spline numbers, but basically there are 3 different types of T50. An early one (Celica), a late one (AE86, AE71 etc) and one in between (T18). The "strong" gearbox is the late one, and it has a bigger front bearing, and a bigger output shaft.
I don't know what configuration the T18 one is in, but I do know about the early and late ones. Since you only have the gearbox itself and not the bellhousing, the easiest way to tell which is which is the shifter position.
The early one has the shifter sort of at the front of the extension housing, and the late one has the shifter right on the end, where the tailshaft goes on.
Posted on: 2005/6/21 6:22
The FookStar
