Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
efi help
_steve_
Posted on: 2005/7/30 15:28
i am geting a efi from an nissan et turbo but i need a Computer can i use a Computer from a nother car
#2
Re: efi help
sunny
Posted on: 2005/7/30 18:04
early delco computers are the easies to adapt if you cant afford an after market one . these were in V/N,P,R and pulsars that had the holden engine i think n13
all u need is a good computer and a pin out map then about ten different colour wire and you can make your loom or get a auto electrician to make one up when it' s close to running you can get chip written for it probably cheaper to buy a link orr wolf or something like that
#3
Re: efi help
SLAM1024
Posted on: 2005/7/31 1:45
is it from a CA18ET? 84-88 Gazelle? If so you could use that ECU, they arnt great but I think it will work vor your application...
#5
Re: efi help
sunny
Posted on: 2005/7/31 12:30
i am geting a efi from an nissan et turbo these were E15t I have been looking at these engines as the next generation replacement good ones (any) are hard to find up here not sure of the resistance of these injectors , might have chack this before you choose a computer .
#6
Re: efi help
1200rallycar
Posted on: 2005/7/31 17:15
delco is pretty easy and cheap (one from JE camira fitted to mine)
resistance of injector can be changed quite easily by fitting a resistor in-line for each injector how are you planning to fit the injection??? to an a-series i pressume? You can view topic.
