Changing valve springs
From SE Melbourne
Hey all,
I'm now up to rebuilding the head and attempting to compress the valve springs on the A12.
I can't get the bottom of the valve sping compressor under the valve springs - as the spring are on an angle and the bottom of the spring is recessed into the head.
Anyone got a good technique for compressing the springs to disassemble the valve assembly?
Mildman
Posted on: 2005/10/11 10:42
Mildman, Datsunless
Re: Changing valve springs
From Durban, South Africa
id take it to the engineers. they do all dat for you. take out everyting n put it all back together again. dont cost dat much n its a pro job.
Posted on: 2005/10/11 10:48
From SE Melbourne
Well I could do that, but I've been enjoying doing everything myself...I've had a few dramas along the way. This is just the latest, but the learning is fun.
Posted on: 2005/10/11 11:03
Mildman, Datsunless
From Adelaide, Australia
The lower part of the valve spring compressor should go at the bottom of the head, on the valve itself.
Posted on: 2005/10/11 11:05
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
yeah kno wat u mean by the fun learning.
recently overhauled my a14 n did it myself. feels good t kno exactly wat your motor is doing any y
Posted on: 2005/10/11 11:14
From SE Melbourne
Hmm...I didn't try that!
The picture that came the tool showed it being done the other way....I'll post some pics soon.
That actually makes sense though...although I guess it doesn't scratch the surface of the valve?
The box of the tool says "No need to remove cylinder head from the engine!"
Instructions:
Place jaws under bottim area of valve spring
Compress valve spring by turning handle and remove valve keeper
Thought I followed the instructions as best I could...see pics
Posted on: 2005/10/11 11:28
Mildman, Datsunless
From Ipswich,QLD
MY way is a bit animal but it works put the head on a piece of crd board covered with a rag ,place head on ground use a spark plug socket ,place it on the top on the valve spring ,give it a wack with a 4 pound hammer and the collets will pop out and you can now remove the valve and spring.......
Posted on: 2005/10/11 11:39
From SE Melbourne
OK...possible to use this bashing method, leads me to one question....how do you put it back together?
Posted on: 2005/10/11 11:56
Mildman, Datsunless
Looking at the pics of what you are doing is correct.
One thing you should do though before using the spring compressor is give the retainers a light tap around the top with a small hammer.
In the pics it looks as though the spring is compressed but the valve and collets are stuck in the retainer.
I have the exact same spring compressor so they definitely work for the job you are trying to do.
What part of SE Melbourne are you in?
Posted on: 2005/10/11 12:12
From SE Melbourne
Good to hear some positive reinforcement...
I'll give the valve stems a few love taps - so if I can loosen the o-rings above the collets.
The whole engine has been a bit festy so I could understand things being stuck together.
By retainer I assume you either mean the o-rings on the top....or the spring caps?
Posted on: 2005/10/11 12:17
Mildman, Datsunless
(1) 2 3 »
