How do u set up a standard a14 carb??? Pls help
From Durban, South Africa
Help needed once again.
Url myt kno i recently overhauled my motor n havin trouble settin it up.
Got the timing sorted out, tink its bout 6deg retard (jus about the spec setting) but stil have a slight pink when i give it full throtle.
Now for the carb. How many screws are there to adjust on the carb? and how do you go about doin it?
messed around with it the other day and got alot more power, but the idle is a bit ruf and the exaust is burning a very dark grey (burning too rich)
how can i set this up properly?
Thanx
P.D.
Posted on: 2005/10/14 11:53
Re: How do u set up a standard a14 carb??? Pls help
See our club Tech Section article "Tune-Up Information
", especially step 6. Check carburetor cold-engine settings
Pick any of the settings for B210, it doesn't really matter much except for emissions; the engine will run good with those settings.
Posted on: 2005/10/15 19:50
