F4W60L and BW diff into '75 120Y questions
From Quairading, Western Australia
Hi guys I have a '75 120Y sedan that has a H150 ,H150 tailshaft and F4W56A
on my old farm hack "The Defect" has a BW diff, BW tailshaft and F4W60L...
the 60L gearbox has WAY better "performance" - the 56A gearbox is sorta like the old 3N71B out of "the Defect" but sorta not...
does the 120Y (B210) F4W56A share the same gearbox yoke spline diamater?
I intend to swap the BW diff over too - I'm thinking of going to "L" - L18 power!!!
failing that: I'd like to stay "A" but I can't find an A14/A15 - exept for a low mileage A15 - $770 - way too much!
Posted on: 2005/11/20 2:19
Re: F4W60L and BW diff into '75 120Y questions
The 56a and 60a transmissions use the same output splines. I'd be surprised if the 60L used a different one. If you have both, compare and let us know.
Posted on: 2005/11/20 8:55
From campbelltown (sydney) australia
if it helps, ive got a 60l in my ute and it still uses stock clutch so must be the same....
Posted on: 2005/11/20 10:59
* caution, sunglasses must be worn to view my ca18det *
