I'm with datsic on that one. A turbo is not required, you could use a supercharger.
I am looking into forced induction as well, and just having rebuilt my 32/36. I would rather keep it. From what I have read so far on the topic, the problem with blowthrough carbies is changes in pressure as the turbo spools up. Carb's work on velocity, not pressure, so the varible boost you get from turbos creates all sorts of mixture problems.
However, if you run a blower (especially if its overdriven, Wally's wagon style) you should make full boost at very low revs, so the pressure change issues will only occur in a short section of the rev range.
The theory (not sure if it is 100% correct) is that a fully boxed carby will 'not know' the difference between atmospheric pressure and 5, 15 or even 30psi of boost, as long as that boost is constant.
