attn brake gurus
From Taupo New Zealand
first question is about brake boosters...
can disconnecting the vacuum to the brake booster affect brake performance in any way other than increasing the efort required at the pedal? I am wanting to disconnect the booster, will this be the same as running no booster at all? I can't see why not myself
second question, on B310 sunny's and quite a lot of the later datsuns, there is a cast manifold thing under the brake master cylinder. It looks to be a tee for the front brake line, but the rear brake line goes in at the bottom and comes out further up on the other side of the casting. I have been told that this is a brake proportioning valve which reduces pressure to the rear brakes, can anyone confirm or correct this? I have converted to rear discs and am going to use a wilwood bias valve, and was thinking of bypassing this cast iron part altogether. Am I on the right track?
Cheers for any replies, I want to rally the sunny this weekend and I'm not happy with the brakes yet....
Posted on: 2006/5/17 11:26
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Re: attn brake gurus
From Christchurch. NZ
yes, and yes sounds like a propoortioning valve.
Posted on: 2006/5/17 11:28
cheers Damon. I hate bad brakes. especially in forests
Posted on: 2006/5/17 11:36
1970 1200 coupe A15
1978 B310 SR16VE
you gotta watch those trees, they jump out at ya when you least expect it.
Posted on: 2006/5/17 11:37
