10a motor meet sunny trans
Not too shy to talk
From Adelaide
does the 10a motor bolt straight onto the sunny trans?
I'm dropping a worked 10a into my 69 1000 coupe and want to upgrade the trans at the same time.
Will i need to shorten the drive shaft?
Thanks
Posted on: 2006/5/27 11:33
Re: 10a motor meet sunny trans
From Perth
I recall you need to shorten the input shaft
The rest I don't remember
Posted on: 2006/5/27 11:59
From sydney
If by 10a you mean A10,and if by drive shaft you mean the tailshaft, I think it will be OK.
If its a 10a rotary I dont know about tailshaft length, but you will need the front yoke to fit the mazda gearbox.
I think the input shaft only needs shortening on the 1000 gearbox if you change from the A10 engine.
Posted on: 2006/5/27 12:20
