(1) 2 3 »
Crystal Headlights
From Brisbane
any running H4 headlights that replace the 7" seal beams, any comment would be great, for or against? i have seen plastic and glass types for sale.
Posted on: 2006/6/15 12:01
Re: Crystal Headlights
From Warburton vic
i used h4 hella inserts i recomend them
Posted on: 2006/6/15 12:06
Hella inserts with relays & a carefully adjusted regulator [where applicable] that delivers maximum voltage but is still within specs. Doesn't get much better than that & I have been using them for 26 years.
Posted on: 2006/6/15 12:11
Love your Datsun.
Treat it well.
From Brisbane
i have been told they plug straight in with no modifications needed?
Posted on: 2006/6/15 12:16
yeah i am running these lights, bolt in with no mods. Am running the same as the standard globes (55/70 i think). Hell of an improvement over the stock lights, but still lacks height on the passengers side.
I'd recomend looking at hyundia H4 inserts. Your local wrecker should sell for about $10 a light. Also straight bolt in replacements i believe
Posted on: 2006/6/15 13:00
From Sydney, Australia
hyundai inserts..baargain idea. I'll go buy up a spare set at the wreckers.
I paid $130 for my Hella H4s. Then some more for the higher powered 90/100 inserts.
If aimed properly, the higher powered inserts aren't much of a defect risk.
Posted on: 2006/6/15 13:08
I run 100/90's in the old 200B & never have a problem. With 100's in the inner, high beam lights it gives me 400watts of foward illumination & the the poor overworked altenator is starting to earn its keep.[Nominal 32 amp load.]
Posted on: 2006/6/15 14:20
Love your Datsun.
Treat it well.
From Sydney
let me know if anyone wants some H4 hella headlights to suit 1200's with or without globes ive got some for sale
would prefer sydney only but may post if the price is right!
Posted on: 2006/6/15 15:19
From sydney,Australia
hey ben you got anymore of those headlights with globes? i am keen for a new set that are actually bright
Posted on: 2006/6/16 10:06
From Burbank, CA
i have crystal headlights, the one thing to think about is that these things usually have glass fronts, so if one gets a stone chip it's more expensive to replace.
Or you can get stone guards if you don't mind the mad max look.
Posted on: 2006/6/16 18:59
|||\ 81 KPB310 /|||
(1) 2 3 »
