Auto meter Custom Dash
From Lismore, NSW
Hey guys, ive decided im gonna make a custom dash with an autometer speedo and tacho and fuel gauge, now my question do i get an electric speedo or mechanical one cause they sell both im not sure. Im gonna use 3mm alluminium for the dash and cover it in padded vinyl the same colour as my car. has anyone done dash's like what im doing if so how hard is it to do, thanx all.
Posted on: 2006/6/18 10:22
Re: Auto meter Custom Dash
From Bendigo, Victoria, Australia.
ive seen a dash just like the 1 u have planned in a ute in a magazine a while ago.
id say go with an electrical speedo because if you have a 5spd or have done any sorta ratio swapping in your gearbox then chances are your speedo is out anyway.
im not to sure how a digital speedo works though.....
Posted on: 2006/6/18 10:28
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Bunbury Western Australia
the electric ones are the go because they accept the standard cable input and the electronics work out the right speed and are easy to callibrate by driving under 45mph for exactly 2 miles no matter what your diff ratio or how often you change your diff ratio the unit is always easy to recallibrate. let me know how your custom dash assembly goes, coz i wouldnt mind doing one myself. cheers.
Posted on: 2006/6/18 10:40
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Lismore, NSW
Hey the gauges im gonna use are called street rod artic white, i kinda want to keep it looking sorta old school, and im not gonna go 5" i gonna get them in 3 3/8" so it doesnt look to over the top. Yeah i didnt know whether the old cars would accept elect speedo but i guess they do. This is the link to the gauges im going to use http://www.autometer.com/cat_gaugedetail.aspx?gid=3486&sid=17 Tye.
Posted on: 2006/6/18 10:56
these are a nice looking guage, should suit the car nicely
Posted on: 2006/6/18 11:13
From Lismore, NSW
im also gonna see if i will have enough room to fit a tacho the same type and size in they are 85.7mm each so i hope theres room for all 3. Does anyone have a straight yes they will or not they wont fit answer ? Dont forget i still gotta have room for my lights/wipers and cig lighter gotta squeeze it between all them. Also is it gonna be possible to wire the water volts and oil gauges up ?
Posted on: 2006/6/18 11:18
From south australia
i dont see why they would not fit as the coupe or ute dash both have 3 large gauges in the standard dash
Posted on: 2006/6/18 11:32
Not too shy to talk
From perth, WA
yeah i tried something similar. just try and make sure that the guages are close enough together that you can see them through your steering wheel when your sitting in your seat, or it will make things a bit more tricky.
good luck
Posted on: 2006/6/18 11:59
1200 sedan A15
From Burbank, CA
get electrical gauges, your install will be much easier.
Posted on: 2006/6/18 20:45
|||\ 81 KPB310 /|||
From Lismore, NSW
so it will be possible to wire up the water oil and volts gauges ?
Posted on: 2006/6/18 21:09
