Alternater wiring
Hey guys,
I'm trying to wire up my A12 alternator. The motor came out of another 1200 and I found that the plug on my loom doesn't match the hole on the back of the alternater. My plug has 2 pins in a T shape configuration and the hole in the alternator has the 2 pins in a parallel configuration.
Has anybody encountered this when perhaps replacing an alternater?
I had a go at wiring it up by the wiring diagram. I have put the heavy white wire with red tracer on the pole "A" which has a little bolt on it.
I have earthed both of the black wires to pole "E".
then I have wired up pole F and N to the white with black and the yellow respectively.
Most importantly the alternator is not charging and I know it's in good nick because the motor and alternater just came out of a perferct running car.
Where do I start?
Posted on: 2006/6/23 4:03
Re: Alternater wiring
I'm not familiar with that one. Are the marked? Usually there is a cast marks "L" or "N" or something.
What brand and model number is the alternator?
Posted on: 2006/6/27 3:10
