lowering?
Not too shy to talk
Iv got a 1200 coupe with standard suspension and want to get it lowered. Whats size lowering blocks should i put in?
I was thinking 2 inches? its got 13 inch rims too.
Posted on: 2006/9/10 5:26
Re: lowering?
From Lismore, NSW
i got 3 inch blocks in mine have a look in my photo gallery, 3inch blocks make them sit nice on 13" rims..
Posted on: 2006/9/10 5:32
Re: lowering?
From San Diego, CA USA
I've got 2 inch lowering block on rear.
3 inch might be too low for the coupe.possible axle u-bolt hit frame on uneven bump....
Posted on: 2006/9/10 6:39
Re: lowering?
From sydney,Australia
i have 2inch blocks in the rear of my ute sittin on 13s and superlow king springs in the front sittin on 15s the ute looks nice and low but want to go abi lower in the rear so am thinkin of puttin in 3inch blocks in
Posted on: 2006/9/10 12:18
Re: lowering?
Of course you could always have the springs reset & do it properly. While they are out you could replace the suspension bushes with urethane ones, & check the shocks to see if they are up to the task.
The springs should come back with new interleaf slider pads, & when it's all together you will enjoy a new level of ride quality & handling.
I have done all this in my coupe, except for the springs, which will get reversed eyes next & the ride quality is great [for a 1200] while handling is noticeably improved.
Posted on: 2006/9/10 17:19
Love your Datsun.
Treat it well.
Re: lowering?
Not too shy to talk
yea i think im going to go with dream74 and use 2 inch blocks. Your coupe looks MINT! then later on when i get some $ will get them reset. Iv already done the front end with gas inserts,nolathane bushes and 120y sway bar. cheerz 4 the advice every1!
Posted on: 2006/9/11 7:34
Re: lowering?
Not too shy to talk
Posted on: 2006/9/13 2:17
Re: lowering?
From Adelaide
How much does it cost to get the rears reset and stiffened up a little?
Posted on: 2006/9/14 6:38
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
