piston questions
Quite a regular
From Houston,Texas. USA
will pistons from the a13 engine work on the a12 engine?
Posted on: 2001/2/23 10:51
Re: piston questions
From San Diego California
Your best bet is the J13 pistons. you need to machine the bore for fit. the pistons
are flat
top giving increased compression. I don't know if they are still available at Nissan
dealers.
Posted on: 2001/2/23 2:35
From Fort Worth, Texas, USA
According to the Nissan Motorsports catalog, the only difference between the A-12 and the A-13 is the increased deck height to accomodate the longer stroke (77mm vs 70mm).
They are supposed to have the same bore. My question is, can you bore the A-12 block to fit A-14/15 pistons?
Posted on: 2001/2/23 3:20
Turbo'ed A15
I'm gonna Turbocharge, Intercool, and Fuel Inject an A15. I have a lot of the parts but still need to buy more. Will the Turbo draw too much oil/pressure from the system though?
Does anyone have a Nismo Oil Pump? see ya
-Andy
Posted on: 2001/2/23 4:54
Its exactly the same block, just a differant engine code stamped on it, so I don't
see why not...
Posted on: 2001/2/25 6:18
I have an a12 motor sitting in my shed that has been bored out with
the a14 piston.
Posted on: 2001/2/27 6:08
