and the L series drives
From Geelong, Vic
well as some people may know i got the last peice of my L series puzzle today, the tailshaft
good news is it goes quite nicely, starts first kick, and can move off from stationarry in 4th
bad news is:
need the gearbox recoed, bearing noise in 1st 2nd and 3rd
L20b has a knock developing, something to do with its former life
axel tramps life a bitch, 2nd gear on gravel gets it going
and it squats badly on gearchanges, its got like 4 leaves including a ute helper in there, it should be stiff
but after the car being undrivable for 6 months in happy that i can atleast see that i have improved one thing, burnout ability
Posted on: 2006/10/4 12:49
Re: and the L series drives
From Adelaide, Australia
Good stuff! You need new rear shocks, get some good oil shocks. All that thrashing it out has made more work for you, need to rebuild it with a few more cc.
Posted on: 2006/10/4 12:58
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Geelong, Vic
nah ive got another engine to put in it, from another thrashed 200b
ill have to find some money for shocks, the old one oil and one gas in the front doesnt seem to be the best pair
but its axel tramping on gravel, thats just bad
Posted on: 2006/10/4 13:01
What are the oil shocks in the rear of the 180b like? Those old tokico shocks seem to last forever.
Posted on: 2006/10/4 13:02
IPRA Build
From Geelong, Vic
ill have a look, i think they were pretty dead when i took them out, ill have a look sometime
Posted on: 2006/10/4 13:04
From Geelong, Vic
took the car for another drive tonight, after putting some panel work on it
found out i need a new clutch, revs but doesnt do a whole lot
also need to find out how far the speedo is out
good news is, WITHOUT having the swaybar attatched, it can go round fair corners fast without body rolling at all
Posted on: 2006/10/5 12:53
From Perth Western Australia
who cares about the box if 4th works, and it takes off in 4th???
My speedo is out 20%, if it says 120, i'm actually doing 100. I have L20b, stanza box, and 14" rims... not sure on the diff ratio (borgwarner). dunno if that helps.
Posted on: 2006/10/5 15:16
PIGDOG wrote:
i'll have to find some money for shocks, the old one oil and one gas in the front doesnt seem to be the best pair
but its axle tramping on gravel, thats just bad
Axle tramp can be controled, .... well, reduced a lot, with the right shocks. Personally I like Konis as they are adjustable & you can dial in the best combination of ride quality & axle control to suit your needs.
If you're going thrashing, then dial up the stiffness, then you can soften them up for a more comfortable ride to the Nationals. Once you know the best positions, this can be done in just minutes.
Best of all, they last almost forever & any wear in the valving can be compensated for with a little more adjustment so that top performance is maintained right to the end of their service lives, .... then you have them rebuilt quite inexpensively.
Can you still buy them new??? I don't know, but Proven Products in Sydney are [were?] Koni agents, so they could be a good place to start.
I have Koni's all round for my 1000 Coupe
Posted on: 2006/10/5 16:36
Love your Datsun.
Treat it well.
From Geelong, Vic
i was planning to start my hunt for some konis soon, then i will hunt down money for them, and it should help control the rear nicely
been taking off in fourth a bit lately, it does is with ease. running L20b stanza box 4.1 diff and 15s, will test the speedo tonight against mums car to see where key speeds are
also im going to be removing the "new" engine this weeked and seeing if its healthier or not
Posted on: 2006/10/6 7:53
