Lemonhead wrote:
I'm going back to standard lifters and see if I have the same problem.
What lifters have you been using up to now? I was thinking of splashing out for the 'weight reduced' type at about $50, ......... each, but if this is what you have been using, then maybe not.
Who does your cams?
Some grinders moly bake, or otherwise moly treat the freshly ground lobes to minimise wear, particularly during the break-in period.
It would seem that the increase of rocker ratio from 1.44 to 1, out to 1.54 to 1 would not be enough in itself to cause any dramas, & the low friction of the roller bearings & roller tip could only be an advantage, so even if the rockers are a little heavier than the stock ones, it still seems difficult to grasp that they might be linked directly to lobe & lifter wear.
The lack of side thrust on the valve tip due to the roller-end on the rocker must surely be a benefit to guide wear, particularly with shortened guides in a race head.
I'm looking forward to the follow up on this.
