« 1 (2) 3 »
Re: what are the best stoppers to use on a 1200 that sees track work
From Geelong, Vic
what model tarago has 11inch rotors, the one ive got has discs the same size as 200b discs, i think i got ripped in the free tarago department
Posted on: 2006/11/9 9:48
From melbourne
According the 2007 DBA catalogue, the 85 - 90 model Toyota Tarago runs a vented 255mm (10.2 inch to be exact) rotor.
So, as it turns out, its not an 11 but a little bit bigger than a straight 10.
After talking to more people, I am now possibly changing my mind & maybe upgrade to a 14" rim & hopefully get a silvia or skyline set up happening for simplicity & availability.
Any ideas?
Posted on: 2006/11/9 9:53
From melbourne
Actually, I think that there is a 279mm (11.16") rotor on the 90 - 2000 model but it has 5 bolt holes not 4.
Posted on: 2006/11/9 9:56
From Geelong, Vic
thats makes more sence, they are good discs to use with landcruiser 4 spots (well they should be)
just have to modify the hub to get the discs to go on nicely
Posted on: 2006/11/9 10:20
From melbourne
Would it be simpler to use a Silvia S13 or S14 complete rotor/caliper/strut as they are already 4 pot?
Posted on: 2006/11/9 10:27
From Wellington New Zealand
E30 bimmer discs and wilwood 4 pots
Posted on: 2006/11/9 10:37
From Geelong, Vic
silvias arent 4 pot till they meet a generous skyline, thats what i thought ne way
EDIT, how hard are the E30 discs to fit? got a mate that might need to donate his discs to me
Posted on: 2006/11/9 10:41
It's been a hell of a long time, but from memory, the E30 disks have an integral bell. The stud pattern is the same, so the disk went over the top of the 1200 hub (it was probably a 120Y strut and hub, they're stronger).
It gave you a 10ish inch disk which just went inside a 13" halliday rim.
There was some fabrication involved to get your favorite willwood caliper to bolt up.
This setup was used to good effect for circuit racing here in NZ...
Posted on: 2006/11/10 9:37
From Adelaide, Australia
You can get a setup from Rods Fabrication on ebay for 280zx struts, you get wilwood superlites, pads, adapter plates and new discs all for around $600. I will be buying that for my struts in the future.
Posted on: 2006/11/10 10:48
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From melbourne
Do you have the link to the eBay site - I cant seem to find it.
Posted on: 2006/11/10 13:01
« 1 (2) 3 »
