u could probably get an A14/15 for about $300, they are in heaps of cars and vans (my a15 is out of a vanette).
With an a14, u need to modify the engine mounts i think, and the g box may not fit it either ( i think the starter is on the other side, i could be wrong, i have been
before...). Because the capacity of the a14 is under 1200 + 15% (i think) , u dont need it engineered legally. Im not sure about exhaust on the a14...
BUT the A14 can rev a lot harder, because it is has a box stroke (thats where the stroke length and the bore diameter is the same)and some think it a better engine, because of
this.
The A15 will drop in more easily and fits the box, although u will need to use one A12 mount, and one off the A15.
The A15 can be bored out to about 1700 cc, and has more torque than the a14 i think.
which ever u choose, try to get a GX head - bigger , better ports.
Whichever u choose, do the brakes - its simple, and very beneficial (also, swap your swaybar with a 120Y one, they are thicker).
hope this helps - and dont assume what ive said is right...
cheers, Linc
PS have u joined my site?
Datsun Directory
www.geocities.com/lump_a_charcoal/DDD.html
