trimming brake calipers??
From New Zealand
Just fitted 120y discs to front of ute, found once fitted though the only mags that will fit are the standard 12" ones because the calipers stick out so far. Need an extra 3-4mm, just wondering how safe it is to trim off this much from the edge of the caliper (there's a heap of meat there). Could use spacers, but cant get a warrant of fitness in nz with these (your roadworthy cert).
Posted on: 2007/4/8 8:03
Re: trimming brake calipers??
From Perth WA
Im sure its going to be harder to pass roadworthy with a pair of calipers with angle grinder marks in them. Maybe try some different wheels?
Posted on: 2007/4/8 10:58
Chris...
From Bendigo, Victoria, Australia.
well what other wheels are you using?
i have some 12" ones (not stock) and they clear mine easy enough.
get other wheels mate. or pass it for a warrant of fitness with the stockies on it and then change the wheels after...
Posted on: 2007/4/8 13:05
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From New Zealand
i've got 6 sets of mags, all rwd, all low offsets, all fit my other datsuns, and none of them clear the calipers. Need 15mm from inside mag face to mounting surface.
Posted on: 2007/4/8 14:23
From The garage, NZ
i found this proiblem aswell when i did my coupe strut conversion.
I got out the grinder and ground down the caliper housing thats in the way. Just do it in bits and try not to heat the metal to harshly.
It look 15 mins and the wheels fit fine now.
paint the cailpers afterwards so it doesnt show the grind marks.
Posted on: 2007/4/8 14:37
From New Zealand
cool, thanks mate thats the type of response i was after. I was gutted when i tried on 5 sets of mags and they all rubbed!!
Posted on: 2007/4/8 15:36
All you need is a gas axe, to remove the bulk of the material, right angle grinder to make it look pretty & a Queensland Guarantee, [She'll be right] You're back on the road again.
Posted on: 2007/4/8 17:21
Love your Datsun.
Treat it well.
