t28 garret turbo housing
need compresor housing that allows hose to clamp on not a flange on the end.
Or does any1no if you can buy the end flange thats straight from a turbo place
as its pointing on an angle and cant get a good enough 45deg or 90deg for it to match up with other pipes.
Posted on: 2007/4/9 17:36
Re: t28 garret turbo housing
From campbelltown (sydney) australia
all you do is take off the front housin and just cuty the corners off the flange and reshape it with an angle grinder with flap disc and put silicon 2 inch joint on it.
Posted on: 2007/4/9 17:59
* caution, sunglasses must be worn to view my ca18det *
have you done this
is dosent look like much meat after you cut the flange part off and grind th other parts that suport the housing...
got any pics???
I thought if the housings i want are comon
or
i can buy the flage with no angle
ill buy it from a shop...
If i cant find 1 soon i might just do what you said...
Posted on: 2007/4/10 7:39
