Browsing this Thread:
1 Anonymous Users
Smoking Problem |
Every morning when i start up my ute A14 motor heavy white smoke comes out the exhaust but as I drive it wears off.Replaced valve stem seals, rings are fine but still smoking. Any ideas why?
Posted on: 2007/4/15 19:45
Re: Smoking Problem |
how heavy is your ute no fuel? might be that its been set to rich or disconnect the choke. it may also be stuck. had that problem last winter.
Posted on: 2007/4/15 21:10
Registered Users Contentmaster Usermaster
Tis a common problem in the A-series at about 150,000 miles.
The valve guides are worn. Replacing the valve stem seals can help some, if you use the "ford" type (Umbrella) seals. If you use either o-ring type or "postive" seal type, it won't help at all.
Solution: New valve guides.
Posted on: 2007/4/16 2:23
