EGR Valve in way of Weber 32/36
From Indiana, USA
Ive been havig problems getting my new Weber 32/36 attached to my 79 b310 (a14). I took the EGR off to fit the carb on, hoping when I put it back on it would fit. I was wrong. It's really close, so I'm wondering if I could grind into the housing a bit. I'm just learning stuff about cars so I could be way off here. What should I do?
Posted on: 2007/5/5 12:58
Re: EGR Valve in way of Weber 32/36
From Burbank, CA
i think that must be why i took mine off.. ( the egr thingie )
Posted on: 2007/5/5 13:16
|||\ 81 KPB310 /|||
From Perth WA
yup take it off and make a blanking plate if need be. All it does is reduce immisions. Or buy a set of extracters for your car!
Posted on: 2007/5/5 14:55
Chris...
From Bunbury Western Australia
yeah you could try grinding the case away a bit at least if you stuff it up it doesn't really matter too much if it is not connected
Posted on: 2007/5/5 14:56
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
