wtb
From Whitsunday's NTH QLD OZ
13x6 jellybeans with 95 mm offset to suit 1200 ute with 1200 disc brakes on the front,
want to run 205 /60 /13 tyres will they fit .
cheers
Posted on: 2007/6/14 7:50
Re: wtb
From southern sydney "the shire"
HERE you go. call Michael on 0432 870 063
Posted on: 2007/6/14 13:19
Re: wtb
Compare these sizes before making a decision. The smaller sizes give good clearance under the front & allow full steering lock. The bigger & wider the tyre, the more, & greater the problems.
Original cross ply tyre. [600x12] 575mm dia
Optional radial tyre. ...[155R 12] 554mm dia
185/60/13. ............................ 552mm dia [my preference for the front]
195/60/13. ............................ 564mm dia [second choice]
205.60/13. ............................ 576mm dia [my choice for rears]
The 205 matches the original cross ply size & will keep your speedo more accurate, while the 185 matches the original radial size & will provide plenty of clearance, even with lowered springs & this is what I run on my 1200 Coupe with 6" rims. It als provides a little rubber 'rake' which is a look that I like.
Posted on: 2007/6/14 13:46
Love your Datsun.
Treat it well.
Re: wtb
what rims r u running , i got sss stanza at the moment , when i try to put anthing wider on the front than the 165,s the hit they hit the strut ,tried some 13 jellybeens but they hit the 1200 disc brake callipers , i have sss stanza stuts that i havent put on yet the jeelybeens fit over but read in the forum that they dont have much suspension travel want to try and stay with the 13s if possible . looked at spacers but not enough thread . ne ideas
cheers
Posted on: 2007/6/18 7:33
