Wrong engine (1400)
I recently (Few weeks ago) bought what I thought was a 1200 bakkie a 1400 nissan. I replaced the carb but stil no idling..what is the problem?
Posted on: 2007/6/18 12:26
Re: Wrong engine (1400)
From Perth WA
ahhhh
got any more info?
Have you got spark?
Have you got fuel?
Have you got compression?
Does the car run but just not idle?
How old/what motor?
Posted on: 2007/6/18 12:35
Chris...
Yes it runs, but doesnt idle.Its a 1400 motor. Ive checked timing etc.replaced the base gasket on the inletmanifold also. It starts alright but with choke assistance. The idling goes up and down - very uneven almost floating?
Posted on: 2007/6/18 12:49
From Adelaide, Australia
Does the carb have a wire with a spark plug looking thingo coming out the front? If it does thats the anti-diesel solenoid, it needs to be plugged to the positive on the coil, if it doesnt make a click sound when plugged in its shagged and needs to be replaced.
Posted on: 2007/6/18 13:24
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Perth WA
ahh thats what it will be! I remember my sunny started to do that but i sold it itsted.
Does anybody know if you can take the needle bit out of it and leave it out?
Posted on: 2007/6/18 13:32
Chris...
From Selah, Washington
Yes I have done that before.
Mike
Posted on: 2007/6/18 13:38
What needle bit?
Ive connected the wire bit to the ignition and it clicks when I turn the key..
Posted on: 2007/6/18 13:45
If it clicks it is working. Does it run better now?
Theo the needle is inside the solenoid. If its not working you can cut the tip of the needle so the car idles but dont remove the whole thing. The solenoid stops fuel going through the idle circuit of the carb stopping it running on when hot, when the ignition is off the solenoid has no power and the needle is seated stopping passing fuel.
Posted on: 2007/6/18 13:57
IPRA Build
Carburettor issue Wrong engine (1400)
Im still struggling with the idling! Ive adjusted the floats as well. I have an electric feul pump, does that have an influence? I want to give up
Posted on: 2007/7/2 12:28
Re: Carburettor issue Wrong engine (1400)
From Toowoomba, Australia
all i did with my solinoid when the wire broke was put a little piece of tube about 5mm long that fits over the needle an that fixed it
Posted on: 2007/7/2 12:47
The substitute for cubic inches is forced induction....
wanted fender mounted mirrors 4 120y
& 120y hubcaps
120y 2dr every day driver
120y 2dr project
