EFI Fuel system for CA18DET - ideas
From SE Melbourne
Next job in the Coupe is the EFI fuel system.
Here's the kind of idea I want to go with, mounted internally on the boot floor of the coupe - rather than externally.
It needs to feed a tuned CA18DET on the race track - so have a couple of pump decisions to make.
I'm thinking of going Carter for the lift pump as I think it can handle being mounted above the level of the fuel tank...but I'm not sure of the flowrates and pressures to use. I am thinking a Carter silver which is 100gallon/hr, 6-8psi should be the go.
Is a Carter Black 100gallon/hr and 15psi overkill?
Then I was planning to run an 044 Bosch EFI (save me ever upgrading again).
And about a litre of surge tank....
For those of you with CA18DETs with some mods (who also maybe race them) - what have you found sucesssful / unsuccessful.
I think the carter silver and black are actually the same price - but I'm also not sure if more pressure could actually be a bad thing in the lift pump.
Carter Black Specs
Carter Silver Specs
Posted on: 2007/6/20 3:01
Mildman, Datsunless
Subject Poster Date
     EFI Fuel system for CA18DET - ideas Mildman 2007/6/20 3:01
       Re: EFI Fuel system for CA18DET - ideas short-coupe 2007/6/20 5:42
       Re: EFI Fuel system for CA18DET - ideas Daveman 2007/6/20 5:53
         Re: EFI Fuel system for CA18DET - ideas Mildman 2007/6/20 7:48
           Re: EFI Fuel system for CA18DET - ideas Mildman 2007/6/20 8:47
             Re: EFI Fuel system for CA18DET - ideas WARDY 2007/6/20 9:00
               Re: EFI Fuel system for CA18DET - ideas phat_dat1200 2007/6/20 9:42
                 Re: EFI Fuel system for CA18DET - ideas ca18det_man 2007/6/20 11:12
                   Re: EFI Fuel system for CA18DET - ideas Mildman 2007/6/20 11:36
                     Re: EFI Fuel system for CA18DET - ideas ca18det_man 2007/6/20 11:47
                       Re: EFI Fuel system for CA18DET - ideas ANGE 2007/6/20 12:00
                       Re: EFI Fuel system for CA18DET - ideas Mildman 2007/6/20 12:06
                         Re: EFI Fuel system for CA18DET - ideas ca18det_man 2007/6/20 12:13
                           Re: EFI Fuel system for CA18DET - ideas Mildman 2007/6/20 12:16
                             Re: EFI Fuel system for CA18DET - ideas short-coupe 2007/6/20 13:29
                               Re: EFI Fuel system for CA18DET - ideas ANGE 2007/6/20 13:32
                                 Re: EFI Fuel system for CA18DET - ideas Mildman 2007/6/20 13:59
                                   Re: EFI Fuel system for CA18DET - ideas matty 2007/6/21 12:57
                                     Re: EFI Fuel system for CA18DET - ideas Mildman 2007/6/21 12:59
                                       Re: EFI Fuel system for CA18DET - ideas crzy_1200_ute 2007/8/10 13:55
                                         Re: EFI Fuel system for CA18DET - ideas Mildman 2007/8/11 17:58
                                           Re: EFI Fuel system for CA18DET - ideas shoom 2007/8/11 18:47
                                             Re: EFI Fuel system for CA18DET - ideas Mildman 2007/8/11 20:57
                                               Re: EFI Fuel system for CA18DET - ideas dog160 2007/8/13 17:33
                                                 Re: EFI Fuel system for CA18DET - ideas Mildman 2007/8/13 23:35
                                                   Re: EFI Fuel system for CA18DET - ideas 1200rallycar 2007/8/13 23:48
                                                     Re: EFI Fuel system for CA18DET - ideas Mildman 2007/8/14 0:17
                                                       Re: EFI Fuel system for CA18DET - ideas Mildman 2007/8/14 19:55
                                                         Re: EFI Fuel system for CA18DET - ideas 1200rallycar 2007/8/14 20:37
                                                           Re: EFI Fuel system for CA18DET - ideas Mildman 2007/8/14 20:38
                     Re: EFI Fuel system for CA18DET - ideas Curtis 2007/6/20 11:57
             Re: EFI Fuel system for CA18DET - ideas short-coupe 2007/6/20 9:35
