Inside Trim eg. Kick Panels and door trims
From Perth
Hello Guys,
I have a 1200 coupe 70 model.
I am looking to get most of the inside trim replaced. alot of the plastics have degraded and have broken off. The boot plastics have never been there since I bought the car. does anyone have any clue as to where I can have them done/made. also my roof lining is a bit torn.
Maybe someone out there makes them in fibreglass????
As for the kick panels. Are they meant to be straight or curved??? I have tried to make some out of wood but I cant get them to bend to the curve properly
I am in Perth WA Australia
Posted on: 2007/7/3 14:38
Re: Inside Trim eg. Kick Panels and door trims
From Geelong, Vic
120fly makes fibreglass and carbon fibre kickpanels and door cards
kick panels should be straight in pretty sure
might be able to help you out with boot plastics, will have to check out the coupe tomorrow and see what the boot plastics are like
Posted on: 2007/7/3 14:51
From Perth
cheers
are you sure that the kick panels are straight. the last 3 coupes I have had, had a curve in them
MMMMMM Carbon Fibre
Posted on: 2007/7/3 15:11
From Geelong, Vic
ill go down and have a look at the coupe today....you are meaning the front kickpanels though, under the dash infront of the doors?
Posted on: 2007/7/5 1:47
From Perth
The ones in front of the doors
Posted on: 2007/7/6 5:09
From Perth WA
hey retal if u find a good motor trimmer in perth who does your work at a good price, i would be interested to know about it, as im looking at getting a lot of retrim work done as well.
Posted on: 2007/7/6 6:32
