Motors
From Sydney
Hey Guys, Im new to the dat 1200 thing so im full of stupid ?s, Does The a14, a15, or even 1600 motor bolts straight into a dato 1200, or does it need some mods of the engine cross member
Posted on: 2007/7/9 10:01
Re: Motors
Quite a regular
From Cairns, Nth Qld
go to the tech section on the left handside of your screen
Posted on: 2007/7/9 10:43
Re: Motors
From sydney
A14 and A15 will be a pretty much basic bolt in , the 1600 is a different type of donk alltogether so would need much more work.
Posted on: 2007/7/9 11:25
Re: Motors
and ca18 det some sr20det
Posted on: 2007/7/9 17:55
Re: Motors
but once again not direct boltin....
a series is the easiest, will bolt in if you have a post 1974 jul ute x member, otherwise just some 2 inchs of steel plate will make you some adaptors for the mounts. check mildmans website, its all listed there (i mean all of it)
Posted on: 2007/7/9 22:32
Re: Motors
From Townsville, Nth Qld
Posted on: 2007/7/10 1:11
Cheers
Davo
