120y booster in datsun 1200 ute QUESTION
what goes in between master and brake lines???
how does it split into both sides as the master has 1 outlet for front and 1 outlet for back.
What can i get lines off to fit the easiest???
like off a modern car that will be at wreckers???
Posted on: 2007/7/22 6:50
Re: 120y booster in datsun 1200 ute QUESTION
Quite a regular
From Adelaide
front goes to a block on the firewall the rear splits into two on the block mounted on the diff connected to the brake hose.
Posted on: 2007/7/22 8:25
From Geelong, Vic
best off going to a brake place and getting them to make up some solid lines
Posted on: 2007/7/22 8:59
