WTB Coilover Springs??? Help
From Newcastle
looking for a set of coilover springs asap so can complete the suspention . . ?
Posted on: 2007/9/6 11:17
Re: WTB Coilover Springs??? Help
From Adelaide, Australia
They are pricey, I dont know how much they charge but manta automotive in adelaide got King springs in for me $190 pair, most places I asked wanted $150 ea spring.
Get your heights worked out first before buying springs. What engine and front suspension you have and what you want to use the car for will also need to be taken into account.
Posted on: 2007/9/6 11:58
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
My pedders cost $120 for the pair through super cheap with a staff discount
Posted on: 2007/9/6 12:27
From australia tasmania
hi i can get springs in what ever you need.
shoot me a e-mail to kyouteki_xex@hotmail.com
include the coil diameter, free high and spring rate you want.
i can get from 2-12kg/mm. if your unsure what rate you need i cna help you figure out somehting from your setup and to suit your needs
Posted on: 2007/9/7 6:08
old skool cool...
www.shakotangarage.com
From Newcastle
hey champ i got a 1200 ute with ca18det. . not sure what rate to use or lenth id like something round 250 300 cm
Posted on: 2007/9/7 7:10
From Bris-Vegas
You could support one of your fellow datsun1200.com members (sssute).
His offering/s : http://maddat.com.au/suspension-parts.php
Pretty sure he offers a discount for members.
Alternatively, fulcrum do a coilover kit that you can use to modify 120Y / 200B / Stanza struts.... A fair bit of work required though & you need to know what you're doing.
Hope this helps.
Posted on: 2007/9/7 7:47
CA18DET '74 1200 ute project
From Geelong, Vic
pretty sure he already has a sssute DIY coilover kit, hes asking for just the springs
you would probably want between 3 and 4 kg spring rate
Posted on: 2007/9/7 10:03
I'm running 225pound/inch springs in the front of mine with a ca18. 225lb/inch ~ 4kg/mm.
They are a pretty good match. Depends what you want. It's a great street setup but if it was a strict race car I'd probably go a bit heavier. Also depends on your shock too obviously
Posted on: 2007/9/7 16:48
