new member needs help
hello all, im a new member from the Phillippines! i'm in the market for a datsun 'ute'. i'd like to know if the square headlight-black plastic grill version is interchangeable with the round headlight-chrome grill-chrome bumper versions? the one available in my country is the square headlight one. i am more of a round headlight guy. would there be any fender/frontend work required or can this be a straight bolt-on affair?
if it is straightforward, where can i attain such pieces? are they avbl brand new? where can i get these? any help would be greatly appreciated!!!
TIA!!!
flip-ute
*pix taken from jalopnik and dragtimes dotcom
Posted on: 2007/10/21 9:34
Re: new member needs help
From Brisbane, Queensland
That red one looks pretty good!
Posted on: 2007/10/21 9:44
wehey! that one yours? i hope you don't mind me using your car as an example. and what a fine example sir!!!
got any tips/info you can share???
Posted on: 2007/10/21 13:17
I've seen a round headlight 1200 ute in Ormoc City, Leyte. I would say it was just a one off sighting.
Member 2332owner might be able to shed some light on whats involved in the swap. I believe you need to modify the radiator support for where the headlights mount.
Australia, Japan or New Zealand will be you best bet for a used metal grill and headlight surrounds.
Posted on: 2007/10/21 13:46
You can even buy a kit to do the conversion. These kits range from just the headlight adapter that allows fitting of the round light in the square hole, right up to a complete kit that includes everything including the round lights & a new coupe/ute grille.
Once you actually have a ute, check back & I'm sure that there are members who can steer you to suitable Japanese websites for these things.
Posted on: 2007/10/21 14:24
Love your Datsun.
Treat it well.
thanks dodgeman! when I saw this car in the round light version in foreign sites, i was immediately hooked. i wanted to make sure that the conversion was an easy possibility before i dive in. Thanks and I will take your advice
phunkdoktaspok,
pinoy ka ba? where do you reside? leyte is really far(im from makati). i'm better off getting the square headlight one and do the conversion. Thanks!!!
Posted on: 2007/10/21 16:38
From Brisbane Australia
well its possibale but it is a little work i have one myself u will need a donar support panel plus the little headlight spring bits that go on the iner gaurd headlight buckets oh and a grill the wiring is a straight plug in
Posted on: 2007/10/21 20:49
Thanks john_13961!
i've also noticed the domestic market is full of long beds. this may take awhile to find the right one...
Posted on: 2007/10/22 12:08
From NSW, Australia
Welcome, i hope your crusing in a 1200 in no time. with the conversion once you know what you need have a look on ebay and you will be suprised at the grills, lights, blinkers all the 1200 parts you could need.
goodluck.
Posted on: 2007/10/22 14:02
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
thanks bigd!
crawling is probably the more operative word, but i want to make sure id ont make any mistakes. thanks for the encourage ment!
i have already seen some tasty pieces on ebay and i'm looking out for them!!
Posted on: 2007/10/23 13:49
