Wanted - turbo set up
Not too shy to talk
From Gracemere QLD
hey i am just wondering if anyone has for sale or knows of either a draw though or blow though turbo set up for sale and what price you are looking at for a reasonalble set up. if not what the cost of building one is???
It is for a Datsun a12 motor. i am pretty shaw it is a gx but that dose not matter!
THanks
Posted on: 2007/11/20 6:13
Re: Wanted - turbo set up
wats it 4
Posted on: 2007/11/20 6:17
From Adelaide, SA
Send member Frankthedolphintrainer a PM. He was making exhaust manifolds not long ago.
Posted on: 2007/11/20 6:42
Not too shy to talk
From Gracemere QLD
it is for a a12 that is in a morris minor.
THanks
From Bris Ozzztraileeaarr
Yep Franks the man with the gun turbo manifolds!! PM him
Posted on: 2007/11/21 4:48
From Brisvegas, oz
hi i can sell you the manifolds for 300 they fit t2 t25 and t28 turbos.
also sell stainless steel carby hats for 200 that fit 32/36 webers. 10 bucks postage anywhere in oz
Posted on: 2007/11/21 5:38
www.camerasplus.com.au
Not too shy to talk
From Gracemere QLD
when you say carby hat do you mean the box that goes around the carby?
Posted on: 2007/11/21 7:00
From Brisvegas, oz
na sits on top its the shiny part in the picture its got a 2.5inch inlet fitted and bolts down from the top
Posted on: 2007/11/21 7:40
From The garage, NZ
any leaking from the carb seals as the carb isnt fully boxed in? heard things. how much boost have you run through it?
edit: i see in your sig that the answer would be 13pounds.
Posted on: 2007/11/21 8:16
From Brisvegas, oz
yeah its actually 14psi i never bothered to change thequote thingy and the webers are built pretty good no leaks and i havnt even had it rebuilt, when i was looking into it i realised that you would get just as much leakage if not more from the full box due to the throttle linkages.
Posted on: 2007/11/21 9:44
