Datsun 1000 Engine Mounts needed URGENTLY
From Sydney
im in desperate need of a set of datsun 1000 engine mounts, can anyone help me out?
Posted on: 2007/12/10 1:23
Re: Datsun 1000 Engine Mounts needed URGENTLY
From Newcastle (NSW)
I think datsun 1200 or 1600 mounts have the same rubber and studs, however are missing the little bit of steel on the underside that gives the mount it's tilt. You can buy new mounts to suit the above and weld on some newly fabricated angles. It shouldn't be hard for someone who is handy with steelwork.
Posted on: 2007/12/10 6:55
Racecar spelled backwards is racecar!
From Perth WA
Or even use the angled bit of a 1000 mount and bolt it together. There is a thread on here about it. "squash" made it i think.
You cant buy em new anymore
Posted on: 2007/12/10 9:03
Chris...
From Sydney
ah ok thanks for the info
Posted on: 2007/12/12 1:14
From Bendigo Victoria
If you can infact use 1200 engine mounts i have some i could sell you
Posted on: 2007/12/12 1:29
