#1 Turbo charging a a12 or a15
Sterling Posted on: 2007/12/10 8:51
can an a12 or a15 engine handle intake pressure? is the compression ratio good for forced intake?
how much psi can the engine overall handle if any?
and what setup would be best? blow through, or in front of the turbo... ?
thanks
#2 Re: Turbo charging a a12 or a15
frankthedolphintrainer Posted on: 2007/12/10 9:09
you should look through some older threads, use the search button.
ive heard of a stock a series running 30 psi no probs and i run 14 psi on my a12 no probs aswell, as for compression its recommended thatyou drop compression but its not nessesary as i stick run stock comp. i would say that a blow through setup is better because you can run a cooler but others may disagree its personal opinion draw throu is generally cheaper
#3 Re: Turbo charging a a12 or a15
Sterling Posted on: 2007/12/10 9:11
thanks man
