Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
how to make reversing lights work
grall3
Posted on: 2007/12/13 7:33
hello, i have an auto 120y that was converted to a manual l20b with a dog leg 5 speed stanza box. But i cant get the reversing light to work, how do i get around this? Thanks in advance
#2
Re: how to make reversing lights work
Tyrie
Posted on: 2007/12/13 7:45
power from ignition (acc?) to switch to lights to earth.
#3
datsun150
Posted on: 2007/12/13 10:32
buy the reverse light switch for the type of gearbox at any auto parts store thy will be able to order you one
#4
Ronald
Posted on: 2007/12/13 23:57
There should already be the wires for the lights in your car still.
just hook them up to the terminals on the switch of your new gbox (if it has 2 terminals). if the new switch only has one terminal then you will need to buy a relay and wire the existing wires to the switch side of the relay. then run a wire from ignition (or even just the battery) to one terminal on the coil side of the relay, then from the other terminal on the coil side, run a wire to the one terminal on the gbox rev. light switch (acting as a ground). Hope this helps
#5
Demo
Posted on: 2007/12/15 0:40
where do the wires meet from switch 2 body????????
i conected everything else if i cant find il go dirrect to reverse light
#6
minitruckin
Posted on: 2007/12/15 15:49
i know it is a bit dodgy but put a switch on the dash,
