engine probs - plz help
From gold coast
ok went down river for swim..got in n drove my ute like 3-4ks the lost all power,coughs,farts then dead...got it going,idels & revs fine then dies when you want it to move....so replaced fillter and tapped webbers to remove any dirt or #### THEN goes good for about two k's and BANG!! massive back fire and no power...started her and ran good if i flogged the ass off it....any help at all would be great ....cheers
Posted on: 2008/1/6 6:57
Re: engine probs - plz help
From Wagga Wagga
now my dad had the same thing! what had happend is someone (idiot) put a small fruit (don't know was too black when they pulled it out) down into his muffler!
the river sounds like the place where it might of happend!
Posted on: 2008/1/6 7:06
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
Those are signs that it is time to rinse out the fuel bowl of the carburetor. It might be some other problem, but its worth doing now and it might solve it.
A simple way is just remove the jets from the outside, rinse in petrol or ether and put back in. It has fixed three of ours 1200s this past year.
Posted on: 2008/1/6 7:07
From gold coast
o ok well i need to look at all possible causes as it mite be many...it has to be carby/fuel flow probs i think...pump,jets? anything could cause it
Posted on: 2008/1/6 7:28
From Sydney (Carlingford)
Had what sounds like the same problem with my ute just yesterday.
I was sure it was a bad load of fuel or a blocked filter or something, but ended up being a faulty fuel flow regulator.
Took that off and replaced with a hose for now and it runs great.
But as you say it could be many things but probably fuel related.
Posted on: 2008/1/6 7:44
From Brisvegas, oz
check all your fuses
Posted on: 2008/1/6 7:50
www.camerasplus.com.au
From gold coast
fuses? whys that
Posted on: 2008/1/6 8:19
From gold coast
ok result....put 20litters of fuel in the ute and a bottle of metho...then ran ok for bout 40ks then pulled up and stalled so i tryed to start it and it refused to then adventually went but ran shocking!!! farting and backfireing loud as hell..(also carby was making wierd noise) then let one big bang out and went ok again...i need a list of possible causes for the machanic to look at so what could it be???....i also thought it cant be the carby as it only happens every now and then
Posted on: 2008/1/12 7:06
This past fall my 1200 did all those things (randomly). It sounds like you are describing my trial. The cause was crud in the bottom of the carburetor, and the fix was two nuts on the outside of the carb. Didn't need to take it apart. Just drain the fuel bowl, rinse the jets and put the two nuts back on.
Posted on: 2008/1/12 7:36
