stanza struts
Not too shy to talk
will stanza struts and callipers bolt right into a 1200 and if so are they capable of handling a ca18?
Posted on: 2008/1/22 9:53
Re: stanza struts
From Melbourne AUS
hey mate check out the tech section and use the search function there is heaps of info on the stanza swap on this site.
they are basically a bolt in upgrade with the right components, and will give you a very noticeable front track increase
they should be up to handling a ca powered 1200 for street duties, not sure about anything beyond that though
good luck
Posted on: 2008/1/22 10:43
1973 B110 A12
