« 1 (2)
Re: tramp rods/slapper bars/caltracts/ozztracts setups whos using what???
From Townsville, Qld
Tyrie you should just hit those bastards with an angle grinder to make them slimmer
Posted on: 2008/3/23 10:47
From Sydney
play with that brake bias much???
Posted on: 2008/3/23 11:04
From Quairading, Western Australia
neither my 120Y's are using caltracs or slapper bars
my July '75 (The Iron Maiden) is A12/56A/H150 drivelined
and the July '74 (The Defect III) is setup with A12/60L 4 speed/ BW68
So I'm not intending to drag them
The Defect IV might be L18T powered - yes I know of a 180B SSS!
Posted on: 2008/3/23 11:35
From Sydney
Jeff Taylor = JTS Heads
Posted on: 2008/3/23 13:48
From campbelltown (sydney) australia
his brother john is the person that both makes the suspension and used to own pedders he still does work if you contact him through jeff
Posted on: 2008/3/23 14:38
* caution, sunglasses must be worn to view my ca18det *
From Sunnybank, Brisbane
im also need to make a decision about caltrack or the like, has anyone got piccys of what works.
be good to see a bit in the wiki about it
Posted on: 2008/3/24 7:48
have a look HERE for pigdogs setup and details ...
Posted on: 2008/3/24 8:09
this is ange's .. very similar to pigdogs ...
Posted on: 2008/3/24 8:12
thanks boofhead there some nice pics
i already have joints and bars from a 4 link setup that i want to use
and pigdogs setup is exactly how i planed to do it
som people have a kind of pivot with another bar and bolt on front coated in rubber that kinda bounces down into the top of leaf spring
but that seems alot harder then pigs setup
hope i can use the pieces off the 4 link if long enough
Posted on: 2008/3/24 10:27
« 1 (2)
