Browsing this Thread:
1 Anonymous Users
Cortina Sway Bar (which model has a factory rear sway bar)? |
From Adelaide, Australia
Anyone know anything about a cortina rear bar fitting a the front of a 1200? Know which model could fit? read here, I'm just not keen to join the forum to ask a question thats all. Its the last comment on the thread.
Posted on: 2008/3/26 11:04
cheap + fast = disaster fast + reliable = expensive cheap + reliable = stock IPRA Build
Re: Cortina Sway Bar (which model has a factory rear sway bar)? |
Not too shy to talk
From england
i think he prob means if the under steer is to much then fit a rear roll bar form a cortina to the REAR. i'm fitting a rear roll bar to my 120y, got one off of an escort
Posted on: 2008/3/26 20:14
From Canberra
yeah looks like he means rear swaybar to the rear.
ps. its a good forum, worth joining :)
Posted on: 2008/3/26 21:22
Quite a regular
What are you using as mount for this? I'm interested in fitting a rear swaybar to my ute, as my wagon used to understeer with a 20mm front swaybar.
Posted on: 2008/3/27 2:55
From Eureka,California
The MKI,II,& III Cortina didn't come with a rear bar.If this helps.
- Doug
Posted on: 2008/3/27 4:36
Joined! Hopefully they have an answer for me on bmsc.com.au
Posted on: 2008/3/27 7:53
From NZ
Quote: angliagt wrote: The MKI,II,& III Cortina didn't come with a rear bar.If this helps. - Doug
The facelift Mk 3 Cortina's (ie the one with what became the Mk 4 dashboard) did. I think maybe the earlier GT version too. (I had one many moons ago before I saw the light!) Mk 4 and 5 did too. I recall it basically just clamped onto the suspension arms and diff and I think they could be adapted to work with leaves (although a fair bit wider than a 1200 I'd think.)
Posted on: 2008/3/27 9:36
Not too shy to talk
From england
white line have front and rear roll bars listed for the 1200 and 120y.
Posted on: 2008/3/31 18:27
From Canberra
whiteline front swaybar is pretty much a painted 120y swaybar I think. I dont want to buy a rear one to find it doesnt fit around a r31 diff... does anyone know if they do?
I had a look under a TF cortina and it has a swaybar as fandatstick described. I took a pic but bluetooth is being gay so i cant get it onto the computer.
Posted on: 2008/3/31 23:18
From Canberra
here's the pic of a cortina, looks like it could be clamped onto the springpack like the nissan comp. bar. Next time i see it I'll have to try and measure the width.
Posted on: 2008/4/4 0:48
