how do you tell a diff ratio.
From cronulla
i want to know how to work out what a diff ratio is.
Posted on: 2008/5/9 12:12
Re: how do you tell a diff ratio.
From malta
what diff do u have???
Posted on: 2008/5/9 12:13
From cronulla
h165 but n general what do you have to do count the teeth or something to work it out.
Posted on: 2008/5/9 12:15
From Geelong, Vic
count teeth on crown wheel and divide it by the number of teeth on the pinion
or just look around the crown wheel till you see some numbers stamped into it....will most likely be the ratio
Posted on: 2008/5/9 12:21
If you know what vehicle that the diferential came from, & you know it was the original, then owners manuals & workshop manuals can give you the info, particulaly if it's still in the car.
Posted on: 2008/5/9 12:30
Love your Datsun.
Treat it well.
From malta
the teeth or diameter of crown and pinion. preferebly the teeth budy
Posted on: 2008/5/9 12:48
From Tracy ,Ca
if it is still in the car you can jack up the car ( use jack stands ofcourse) place car in nuetral and mark and turn driveshaft count the number of times it takes to turn wheel one time this is your ratio
Posted on: 2008/5/9 19:30
From Fort Worth, Texas, USA
Do the math! I have a 4.11:1 R&P in a car that has "39" stamped on the ring gear but definitely has 41 teeth.
As for turning the driveshaft, make sure both wheels turn or the spider gears in the differential could throw the count off. Well, now that I've said that I'm beginning to doubt myself. Am I full of crap on that last warning?
Posted on: 2008/5/9 23:23
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
From gold coast QLD.
No your not full of crap,unless the diff is locked you cant simply jack it up and count revolutions as the spider gears will give a false rotation count.This was all covered recently in another post.
If you dont want to pull the diff out do this:
With the car on the ground,place a chalk mark on the tailshaft and another on the back tyre at 12 o'clock,lie on the ground where you can see the tailshaft and have a mate slowly push the car forward one revolution of the rear wheel till the chalkmark is back to 12 o'clock.Whilst being moved one revolution count the revolutions of the tailshaft eg.3.9 turns..4.1 turns etc.
Cheers
Posted on: 2008/5/9 23:45
From Seattle ,WA.
agro4 - I asked the same question a while back, heres the thread....
http://datsun1200.com/modules/newbb/v ... topic_id=32422&forum=1&20
Posted on: 2008/5/10 1:01
