Ute sills on a Coupe?
Hi all
I'm sure this is a question that has been covered many times before, but I have searched the forums, and the wiki and can't find the answer.
Will Ute sills fit on a coupe? I am presuming that they would be too short, because the coupe doors are longer and the sills run to the trailing edge of the door.
The aftermarket panel guy that I just bought some guards and a bonnet from claimed they would fit (but admitted that he'd only ever sold stuff to ute guys).
I guess if they don't fit I'll just have to get some rolled at a sheet metal joint - maybe I could go for some galvanised ones in this case?
Cheers
Luke
Posted on: 2008/7/5 16:52
Re: Ute sills on a Coupe?
They are too short for a coupe. Ute doors are same length as 4-dr fronts.
Posted on: 2008/7/5 21:37
From Brisbane
yes they fit, they are just 1mm plate bent into the shape of the sill. they are longer anyway. that's what i bought from panel house from up here in brisbane, it was after market, not nissan
Posted on: 2008/7/6 2:14
From Tamworth , NSW
yep, i bought a sill from mark gibbs panel house, and it was way long, i had to cut it down for the ute.
bout 88 dollars from memory.
Posted on: 2008/7/6 2:40
As DD stated, Ute sills are shorter.
They can be made to fit though.
thanks guys.
So sounds like the after market ones could be long enough. I've been quoted $80 for both sills, so it sounds like the deal's ok.
I guess I could buy a 3rd one and cut it up if they turn out to be too short.
Posted on: 2008/7/6 7:13
