« 1 (2) 3 »
#11 Re: Wrecking 200B Sedan
DatsAndy Posted on: 2008/10/2 10:49
Ah think it was. Has had some hoses blocked through the firewall.
#12 Re: Wrecking 200B Sedan
Posted on: 2008/10/2 12:57
want to swap an air con front dual pulley off the crank for a single one for a non air coned car?
will send you one and pay post both ways?
#13 Re: Wrecking 200B Sedan
DatsAndy Posted on: 2008/10/2 13:05
Sorry must be tired that confused me. So you want the Dual pulley ?
#14 Re: Wrecking 200B Sedan
Posted on: 2008/10/2 13:15
yeah... as ive got a full air con set up to install. got an aseries set up to but will need the L series pulley when i convert
#15 Re: Wrecking 200B Sedan
DatsAndy Posted on: 2008/10/2 13:19
Sweet mate. Also have a Air con unit from an A14 Is that any good to you ? Cheers Andrew. Actually will have to Double check if it has the Double pulley. Back in 5
Edit: Yep has Dual Pulley.
#16 Re: Wrecking 200B Sedan
hotrocket Posted on: 2008/10/2 22:52
do you still have aircon pump and mounting bracket? .....$?
#17 Re: Wrecking 200B Sedan
DatsAndy Posted on: 2008/10/3 0:04
Will have a look today mate but i dont think the PUMP is there. Have an Aircon Pump and Mounting Bracket for an A14 though.
#18 Re: Wrecking 200B Sedan
rileymoore Posted on: 2008/10/3 7:20
are any of the front end parts like bonnet or radiator support exchangeable on a 180 B?? i know most of the cosmetic parts dont but still not sure...
#19 Re: Wrecking 200B Sedan
TUF-110 Posted on: 2008/10/3 7:45
Naa mate a 180b and a 200b are completely different datsuns barely anything on them is interchangable
#20 Re: Wrecking 200B Sedan
rileymoore Posted on: 2008/10/3 7:52
check out my forsale post then :)
« 1 (2) 3 »
