« 1 (2)
Re: Simmo's 1200 CA18DET ute
From perth
THROW OUT NOTHING
until car is finished.you may want bits of the body harness, plugs, relay sockets etc nuts, bolts, rubber grommets.......
you get the picture
there is a little grey plug near the fuse block that is for diagnostics. if you use factory ecu this only takes a couple wires to have it working.
dazza
good luck
Posted on: 2008/11/22 5:28
Not too shy to talk
its been a while, update
gearbox tunnel is fully welded in and the gear box painted. New freshly painted hardcover on! here is some pics
[img=http://img383.imageshack.us/img383/1286/dscf0016ni8.th.jpg]
[img=http://img383.imageshack.us/img383/7704/dscf0014ms4.th.jpg]
[img=http://img383.imageshack.us/img383/9410/dscf0013mq5.th.jpg]
not too far away now!
Posted on: 2009/1/6 10:32
Boost, Boost ..... and more Boost
CA18DET 1200 ute 165hp (stock CA)
97 Triton 4x4 daily
From Brisbane
mmm does look very nice...
Posted on: 2009/1/6 10:59
If you want more inches, stroke it
From Bathurst - NSW
who did you get your hardcover from?
Posted on: 2009/1/6 11:04
From Brisvegas, oz
i noticed a few posts ago you asked what else you could take out of the engine bay.... i would say to get rid of that massive relay box, you should only need half of them if any (put the ones you need in the cabin aswell)
Posted on: 2009/1/6 11:42
www.camerasplus.com.au
Not too shy to talk
cheers guys, i got the hardcover off ebay! it came with all fittings and struts, quite impressed with it myself!
Posted on: 2009/1/6 22:04
97 Triton 4x4 daily
From Stray-ya
Nice work Simmo.
A CA had always been my plan for the ute, but I couldn't justify the time and expense......
I'll buy it back off ya when you're done
Posted on: 2009/1/7 6:15
Utes and Roots
Not too shy to talk
haha, i don't think so mate! i will be keeping her for a while after this BIG expense. It's guna be even better than before!
Posted on: 2009/1/8 9:41
97 Triton 4x4 daily
« 1 (2)
