a15 electronic distributor
From New Zealand
an anybody help identify this dizzy i got with an a15 engine?? I'm in NZ if that helps, and have no idea if its out of a vanette, if its an e15 dizzy modified or something else. The
identifying numbers on the outside are:
D4R80-08 2404
22100 11M00
identifying numbers on the inside are E12-61
the base plate/adjustor plate has been modified to fit also (can see this in photo 4). There's no hole for a screw to go through anymore, just a chunk of metal to bolt bown on with a washer. Also the cap screws on, not the usual clips. Thanks
Posted on: 2008/12/7 6:01
Subject Poster Date
     a15 electronic distributor grant76 2008/12/7 6:01
       Re: a15 electronic distributor ddgonzal 2008/12/7 7:30
         Re: a15 electronic distributor A14force 2008/12/7 7:37
           Re: a15 electronic distributor ddgonzal 2008/12/7 7:49
             Re: a15 electronic distributor tommo73 2008/12/7 8:07
               Re: a15 electronic distributor woody 2008/12/7 8:27
                 Re: a15 electronic distributor grant76 2008/12/7 8:34
                   Re: a15 electronic distributor A14force 2008/12/8 5:30
                     Re: a15 electronic distributor tommo73 2008/12/8 8:02
