Flywheel interchange
From Murray Bridge, SA
will an a14 flywheel work on a a12?
Posted on: 2008/12/16 0:56
Cars:
1973 Datsun 1200 sedan (Project)
19?? Datsun 1200 sedan (Parts Car)
A12 crankin
Re: Flywheel interchange
From Melbourne, Australia
yes just different weights slightly
Posted on: 2008/12/16 1:13
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
For some reason 2.7kgs comes to mind. I think this is theweight difference between the two.
I weighed them at the beginning of the year.
Anyhow the A10 flywheel is the one that needs a bit of work to fit to an A14 (bolt holes resized). Pretty sure A12 has the same sized holes.
Posted on: 2008/12/16 2:30
Yes, early engines (pre-1974 -- both A10 and A12) use different bolt sizes than late engines (1974-up). The difference is small: early used 3/8 inch bolts, late used 10 mm bolts. See A Engine Redesign
Posted on: 2008/12/16 4:47
