F4W60A oil capacity??
From Los Angeles,CA
Anyone know how much oil the F4W60A gearbox is supposed to have?
Posted on: 2009/1/3 21:36
Re: F4W60A oil capacity??
1.3 liter is what a dry 60-series 4-speed takes. Typically you will fill it slowly, until it starts to come out the filler hole.
Specification is API GL-4. 90-weight is traditionally used, but a more modern 75W-140 is probably best -- it can handle low temp and high temp both.
I used 80W90 since it is the east expensive. But 85W-140 is better at high temps (think running on freeway high revs) and only a bit more money. Or just use a diff cooler for racing.
Posted on: 2009/1/3 22:07
