Re: upsprung weight
From Adelaide
If you are going to be circuit racing you will need vented disks, but you dont need 32mm or 36mm gtr disks, they will cool far to efficiently for such a light car. Disk diameter has the most affect on light weight cars.
We have just finished developing a new 280mm x 22mm 4spot brake kit with custom ally hub with coil-overs and camber tops with a total weight of only 20.5kg per side.
This set up will fit under 15inch wheels and some 14inch. And is avalible in 4 and 5 stud.
Posted on: 2009/1/21 10:57
Subject Poster Date
     upsprung weight 1200rallycar 2009/1/20 6:30
       Re: upsprung weight ddgonzal 2009/1/20 6:38
         Re: upsprung weight 1000Coupe 2009/1/20 7:35
           Re: upsprung weight bert 2009/1/20 7:45
             Re: upsprung weight wolki101 2009/1/20 9:17
               Re: upsprung weight dazza1200 2009/1/20 10:06
                 Re: upsprung weight reuby_tuesday 2009/1/20 10:48
                   Re: upsprung weight wolki101 2009/1/20 11:24
                     Re: upsprung weight ddgonzal 2009/1/20 13:31
                       Re: upsprung weight nick_m 2009/1/20 18:34
                         Re: upsprung weight cheater_5 2009/1/20 21:30
                           Re: upsprung weight nick_m 2009/1/20 21:45
                             Re: upsprung weight 1200rallycar 2009/1/21 1:33
                             Re: upsprung weight cheater_5 2009/1/21 3:56
         Re: upsprung weight retrorally 2009/1/21 7:12
           Re: upsprung weight dazza1200 2009/1/21 9:37
             Re: upsprung weight bobthebuilder 2009/1/21 10:06
               Re: upsprung weight sssute 2009/1/21 10:57
