need help theres water in the oil of my a12 in my 120y.
Hi i need help theres water in the oil of my a12 in my 120y.
whats the most common cause of this?
it still runs ok.
any help would be good.
Posted on: 2009/1/24 7:34
Re: need help theres water in the oil of my a12 in my 120y.
From Far, far away
Water & oil!?!?!
You've got me stumped mate, but you've sure come to the right place. Someone will know.
Posted on: 2009/1/24 7:36
it looks like an off milk shake.
Posted on: 2009/1/24 7:40
From newcastle, NSW
Blown head gasket? thats usually the cause. Is it miky in the radiator or the oil filler cap?
Posted on: 2009/1/24 7:45
From Freo
water in the oil,
common things, corroded head, blown head gasket, cracked head, cracked block...
basicaly, comp test, cylinder leakage test,
cooling system pressure test with the plugs out..
it will point you in the right direction...
A15 PSI Project Motor
'72 CB750k,
From port elliot , SA
head gasket is gone
Posted on: 2009/1/24 7:46
its real milky on the bottom of the oil cap.
so pull the head off?
Posted on: 2009/1/24 7:51
From Far, far away
Oh, I thought you were being sarcastic (hence the ?!?!).
Def the head gasket.
EDIT: Had the exact same symptom with my old ute. Gasket was blown between 2nd and 3rd cylinder.
ok i will do some tests tomorrow and i will let u know thw out come.
thanks Heaps.
Posted on: 2009/1/24 7:54
From newcastle, NSW
YEP! off with its head!
let us know how you go.
Posted on: 2009/1/24 8:01
