#1 rpm connection
Sumith Posted on: 2009/3/20 7:47
HI Guys
how b210 rpm gauge is working, is it connected by a cable like speedometer or is it electrical,
Thanks
Regards
sumith
#2 Re: rpm connection
pepper Posted on: 2009/3/20 7:49
electrical
#3 Re: rpm connection
Sumith Posted on: 2009/3/20 7:51
Hi pepper
what are connection needed to make it work ,mine is not working
Thanks
Regards
Sumith
#4 Re: rpm connection
pepper Posted on: 2009/3/20 7:54
do a search, you will find pictures, diagrams and all sorts of info.
you need to get a hold of a service manual and have a bit of a read mate.
#5 Re: rpm connection
Pendles Posted on: 2009/3/20 7:59
But this Sumith:
Ebay Manual
It'll save alot of questions later on.
#6 Re: rpm connection
woody Posted on: 2009/3/20 8:24
hi sumith. the wire connects to the negative (-) side of the coil, on aftermarket gauges the wire is normally green. and there is a red for power and a black for negative. but on the standard tacho i dont know what they are.
hope that helps.
cheers kurt
#7 Re: rpm connection
Pendles Posted on: 2009/3/20 8:50
not sure if its the 210 is the same as the 1200 but this may help:
factory tacho wiring
#8 Re: rpm connection
Sumith Posted on: 2009/3/20 9:26
Hi Guys
Got a Clear Picture now very clear , have lot of things for the week end ,wow, ill finish them all
,shame to say i am a son of mechanic who has certified by Mitsubishi cooperation in Japan
Thanks
Reagrds
sumith
