« 1 (2)
Re: front brakes locking up!!!
From northern 'burbs adelaide
turnsout it was the dome on the pushrod ... so i got an adjustable one from the local mechanic and modified it to fit with no effect on the piston when idle ... without a booster i can get the whole car to lock up with heavy pressure on the pedal and it pulls up really nice when just driving normal so i wouldnt think that using a booster would give you any real benifit (for all those thinking of doing it)
Posted on: 2009/4/14 9:38
BAH! so I pulled it out and modified the dome and got an adjustable rod and its still friken happening!!! if it was the m/c piston wouldnt I have a problem when I go to bleed the brakes because it wouldnt take any new fluid and wouldnt flow out of the bleeder valve on the caliper?
Posted on: 2009/4/15 8:56
From Toowoomba, Qld
After the car has been sitting for a little while, how much free-play do you have in the pedal?
You should have a couple of mm before the rod starts to push the piston.
Were the calipers new/reconditioned or secondhand ones that have been sitting for a considerable amount of time?
Posted on: 2009/4/15 9:22
the calipers were fine coz i gave them a tidy up myself and the pistons arent sticky
Posted on: 2009/4/15 10:23
From Melbourne, Oz
Could there be a problem with the rear drums that are affecting the front's?
I dont know exactly how a split front/back sistem works? but they are still relativ to eachother. my front break's yousto hardly work at all and it was because my rear drums were incorectly adjusted
Posted on: 2009/4/15 10:58
"I hav achieved wood"
From Toowoomba, Qld
when you tidied up the calipers did you inspect the large 'square' ring that seals the piston?
was it hard or still soft?
a hard sealing ring in the calipers will sometimes cause this problem as it doesn't help to retract the piston properly when you take your foot of the pedal.
Posted on: 2009/4/15 12:00
the M/C was the problem ... turns out that the freeplay on the piston was only like half a millimetre so when i put the washer that holds the pushrod in, the piston couldnt release so i've had to put my old leaky one back on grrrr
Posted on: 2009/4/16 10:10
« 1 (2)
