what size wheels
From brisbane, QLD
hey everyone im looking at running a 120y front break setup on my 1983 1200 ute.. wat mods are need to to this and wat size wheel and tryes can i fit..
im putting a ca18det in it as well and iterested in your opinion on this break setup..
any info is a help
thanks blair..
Posted on: 2009/4/20 11:47
Clint at Profile Autosports and tuning for all mechanical needs and dyno tuning Brisbane..
current rides..
02 hilux daily.
ca18det 1200 ute
Re: what size wheels
From Wagga Wagga, NSW
13x7's in a zero or slightly negative offset, 250mm silvia disk brakes on the 120y strut.
need more info? the search buttons your friend
Posted on: 2009/4/20 12:04
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From The garage, NZ
^read the question jake you muppet.
120y front struts and brakes bolt right into the ute. Use the 1200 top hats though as the 120y ones suck (and make the car higher). Use all the same piping etc, they bolt straight in. Use anything bigger than a 12" wheel over those tiny brakes.
They make a really good upgrade over the standard drums all round but I would be looking towards something much bigger/thicker/a bit more up to the job if you are going for a CA18DET install.
Many use the S13 brakes on the 120y struts with a caliper bracket and the 250mm 4 stud rotors over the top of a slightly turned down hub which is a very cheap upgrade. You can fit some 13's over the s13 brakes with small clearance but 14's fit slightly better, unfortunately.
EDIT: for the love of god please dont make another cookie cut out ca18det 1200 ute with 17's and a big bore that does phat skids and looks baller.
Posted on: 2009/4/21 7:15
^^ suck my dick chris, you faggot
Posted on: 2009/4/21 7:36
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From The garage, NZ
Posted on: 2009/4/21 8:46
From brisbane, QLD
hey mate thanks for the info it help's heaps.. yeah i was a bit worried about the 120y setup on the ca18..
nar mate not goin the bling bling.. just nice a simple..
thanks again..
blair
Posted on: 2009/4/21 9:56
current rides..
02 hilux daily.
ca18det 1200 ute
From Melbourne ( West )
Email sent
Posted on: 2009/4/21 12:05
'78 Ute CA18det Project
No matter where you go... There you are
